Update on 2.30.2 Anonymous |
thanks for not giving up. I almost have.
This build is Much much better.
Everything worked the first time I fired it up. The acc, the led, everything. Then to give it the true test I tried to turn it off. It would not stop working. Hitting on the X to close it did not work. So, I had to close it by going into task manager and getting rid of it. It was there after hitting red x.
Next I rebooted my machine and tried to open it. It gave me several error messages about Invalid tag, error in depth, sych and rgb. All values were (-5) if this helps.
The Led just blinked green with no laser light.
I think you have did a great job. You are on your way. We are so close.
I will keep you informed. Got to go to bed, big working day Wed.
Mel
Mel,
When you get a chance please attach the c:\RoboRealm.log file as that will help us know where things went wrong.
Perhaps your browser was caching the previous version? Strange that this one made such a difference when only debugging was added.
OK, The latest 30.02 has worked much better. I got it to come on and work about 4 times. When it works , it works beautiful. But it did not want to stop working. Rebooting does nothing to make it run. When I turn on roborealm, I get a blinking green light. Then, a little later a squigley little red laser light. Then a short time after, the popups comeup and say about errors in synch, lens, tag,rgb, ect. all values are -5 except one is -1. The only way to get out of that is CTRL-ALT-DEL and then stop RR in the task manager. When it decides to work, everything in it works. We are making progress, I believe. Got to get some sleep. work WED. now midnight.
Have a Blessed Night!!! God Bless You!
Mel
