VB script..
BalanaR from Malaysia  [2 posts]
Can anybody guide me thru how or what should i write on my VB Script source program so that i could make an output to my buzzer in my pc or perhaps external LED. Really need some help here. Thanks in advance.
Bala.
What device are you using to connect to the PC and the LED? If you have an old fashion parallel port you can use the Parallel Port module to control one of the pins to turn an led on and off. You should be able to use the Parallel port GUI interface to do this manually and can then specify a variable that would cause the signal to be high or low (LED on or off).
http://www.roborealm.com/help/Parallel_Port.php
