about the I2C bus on the serializer board
fred miller from United States  [3 posts]
Steven what variables are they on the I2C bus to read from
mostly TPA81 and how do i write them
fred miller from United States  [72 posts] 16 year
Steven have any ideas on this
and the TPA81  variables and the list of TPA81 api commands
Fred,
RR just supports the generic i2c command to the serializer that is a simple pass through command. RoboticsConnection would know more about connecting the serializer to the TPA81 ... or perhaps even the vendors of the TPA81 could give you some insight as to what commands they send out on the i2c bus.
ok thanks STEVEN
will look into it,looking at building it this week
Steven on using the I2C bus
SetVariable "my_command", "i2c r 4 1"
in a VBScript module to query the line following sensor
what does r 4 1 meen in your example
Have a look at page 33 Example 5 in
http://www.roboticsconnection.com/multimedia/docs/Serializer_3.0_UserGuide.pdf
to query a TPA81
Note that RR just passes the text right though so the format/meaning of each of the numbers is entirely based on the device you are querying.
thanks alot Steven,i didnt see that
STEVEN next question on using TPA81 it there a module that can take the 8 reading and then average them and compare to ambient temperature and get a difference ,also before i take the reading i need to convert celsius to fahrenheit
is there a way it can be done or any ideas
Have a look at the Filter Variables
http://www.roborealm.com/help/Filter_Variables.php
and select the variable that contains the value and the memory size (past values) to 8 and the method to mean.
Then use a VBScript module with the following code assuming your variable is called "temperature". Note the VBScript module should be AFTER the filter variable.
' get your temperature reading (already averaged)
temp = GetVariable("temperature")
' determine difference from this and past value
diff = temp - GetVariable("last_temperature")
' convert to fahrenheit
diff = ((diff / 5 ) * 9 ) + 32
' save
SetVariable "temperature_difference", diff
' update value for next iteration
SetVariable "last_temperature", temp
thanks a whole lot Steven,like always you are greatest at finding solutions
