Panasonic BL-C10A Network Camera &RR
 [29 posts]
Anyone sucessfull at interfacing the Panasonic BL-C10A Network camera to RR?
Since the camera delivers HTTP scripts and tabs to a web browser, I am unable to directly view the image.
Specs: http://panasonic.net/pcc/products/netwkcam/lineup/bl-c10/index.html
Thanks in advance.
D.M.
DM,
Seems like it is possible if you know the correct url. If you don't (which is probably the reason for your post) do you know of one of these online or are you able to place your online for us to test and see what the url might be?
You could click on any of the links at this site to view the URLs for the camera.
http://forum.networkwebcams.com/viewtopic.php?t=553
The html page for each is displayed. My camera is removed from the network to attempt the interface with RR. These are the same url command to control and view the image, but with buttons, etc. I'm not sure how to just view the image without processing the control buttons, yet.
The following robofile will connect to the first camera in that list. Have a look at the modules url and configure that for your own usage. It will probably look something like
http://192.168.1.X/nphMotionJpeg?Resolution=320x240&Quality=Standard
where X is the last digit of the IP address (assuming you are using a 192 local area addres). Also note that the robofile is using port 5001 which may not be the same one as you are. The first part of the url (i.e domain and port number) should look the same like you were to access the camera from a web browser.
Thank you. I'll try it at the next opportunity!
