Can i use GigE Camera to work with RoboRealm?
Yang from China  [1 posts]
hi,
Normally we used GigE Cameras in our system, such as Basler.
is it possible to use it in RoboRealm? and how i do if possible?
also you can introduce some camera to me, which are easy to use with RoboRealm, and low cost.
we are researching...
thx. Yang
Yang,
As long as the camera comes with a DirectX GigE interface it should work with RoboRealm. You will have to check with the Vendor to see if that Windows interface is supported. If it is then you should be fine.
We don't have much experiance with GigE cameras but have worked with Gevicam cameras with RoboRealm.
http://www.gevicam.com/products/standardgigecameras.html
