Scripting problem
Dashie from Singapore  [1 posts]
I am having some problem with VB scripting? I'm trying to send a value to PIC using serial port in order to control the movement of two  motors. may i know how to set the variable to 0 when there is no object detected?  below example of my code.
cogX = GetVariable("COG_X")
cogArea = GetVariable("COG_AREA")
SetVariable "X_Value", xValue
SetVariable "Area_Value", areaValue
if cogArea < 3000 then
        areaValue = 1
else
    if cogArea > 3300 then
        areaValue = 2
else
        areaValue = 0
end if
end if
if cogX < 150 then
        xValue = 3
else
    if cogX > 160 then
        xValue = 4
else
        xValue = 0
end if
end if
Using COG_AREA is one way, COG_BOX_SIZE is another that we typically use ... but either should work out ok.
Try moving
to AFTER you set the values and that should work much better. More like
if cogArea = 0 then
  SetVariable "X_Value", 0
  SetVariable "Area_Value", 0
else
        areaValue = 1
  elseif cogArea > 3300 then
        areaValue = 2
  else
        areaValue = 0
  end if
  if cogX < 150 then
    xValue = 3
  elseif cogX > 160 then
    xValue = 4
  else
    xValue = 0
  end if
end if
Your code work like a charm.
Thx steven :)
