Controlling motors of iRobot Create through VB script program Ishwarya from United States [2 posts] |
I'm trying to write a script using the VB script program in RoboRealm to cause iRobot Create to respond to the position of a COG marker and move appropriately. Following is a piece from my script (it is only a rough, incomplete version):
'Find the middle of the horizontal image
centerX=GetVariable("IMAGE_WIDTH")/2
centery=GetVariable("IMAGE_HEIGHT")/2
SetVariable "COG_X", cogX
SafeRange=5
'if image is within the center with a small range
'then move straight
if COG_X = centerx + SafeRange
then left_motor = 128
right_motor = 128
if COG_X = centerx - SafeRange
right_motor = 128
if COG_X > (centerx + SafeRange)
then left_motor = 200
right_motor = 128
if COG_X < (centerx - SafeRange)
right_motor = 200
SetVariable "left_motor", left_motor
SetVariable "right_motor", right_motor
_________________________________
It is not working though, and I think it is an interfacing issue. I can't seem to find the iRobot's motor variables to use in the script. Can I please receive some immediate help?
Ishwarya
Ishwarya,
Check your code. You are missing a bunch of end ifs and you cannot compare for equality to the COG as it is most likely not the exact value. Also you need a GetVariable and NOT a setVariable for the COG_X.
Also careful with typecase. In VB centerx and centerX are the same, not so in most other languages. So it is not incorrect but just good form to use the same typecase.
Note that we also have Python and now C as similar modules to the VB one in case you are more comfortable with those languages. Here's your simplified fixed code:
centerX = GetVariable("IMAGE_WIDTH")/2
centerY = GetVariable("IMAGE_HEIGHT")/2
cogX = GetVariable("COG_X")
SafeRange=5
if cogX > (centerX + SafeRange) then
left_motor = 200
right_motor = 128
else
if cogX < (centerX - SafeRange) then
left_motor = 128
right_motor = 200
else
'then move straight
left_motor = 128
right_motor = 128
end if
end if
Thanks! As is evident, I know very little VB syntax, but am pretty comfortable with C++. I will use the Cscript program-- I didn't know it existed. I assume it comes automatically with a purchased license (will obtain soon) ?
Ishwarya
Ishwarya,
No worries, the CScript didn't exist until about 3 days ago! So most people are not aware of it.
Yes, the trial and the purchased copy contain the same functionality with the purchased copy just not expiring after 30 days.
