Activate the "Train" button using VB6 + RR API jorge holguin from United States [13 posts] |
How can I activate the "Train" button using VB6 + RR API
in the Shape_Match module?
I found in the documentation the command: pushbutton "Shape_Match", 0, "Train".
But I do not have a clue how to use it in VB6.
Any advice?
njorge,
Sorry for the delay on this ... it is now live in version 2.25.2
What we did was add a small checkbox in the Train window (after you press the Train button) that tells RoboRealm to monitor that folder for any changes. If a file is added, deleted or updated the module will retrain on the folder's content. This helps to keep the module in sync with the folder contents.
Can you give it a try and see if this meets your needs?
Well, This means that now my VB6 aplication does not need to have a button to activate the train option in the module.
It is wise and it works!.
Thanks a lot.
