Robotics Connection Serializer V3 Servo Problem Scott Thompson from United States [11 posts] |
Connected a couple of Hitec servos to the Robotics Connection Serializer V3 board (may be a similar issue to V2 of the same board). One servo connected to digital I/O pin #9 (corresponds to servo #2) does not move with any of the servo pins. Digital pin #8 (corresponds to servo #1) works fine.
I have verified proper operation using a simple serial port terminal program, typing in the command "servo 2:50" and the servo moves to the desired position.
Please double-check servo operation w.r.t. "Robotics Connection Traxster" module in RR.
Thank you,
--Scott Thompson
Scott,
You are correct! Seems that a "servo 9:50" command was being issued incorrectly. This has now been fixed in 2.24.10. Thanks for the tip.
