Scale with large images Clint Chapman from Canada [20 posts] |
The scale module seems to have problems with large images. See attached.
Clint,
This issue has been fixed. The problem was in an optimization that we added to increase the speed in scaling. This optimization was set to a slightly different size than what you were using. Nevertheless, if you download ver2.20.6 it fix this issue.
Thanks STeven. That fixed the image scaling but now annotations are not displaying correctly after scaling.
scaling_annotation.zip
Clint,
Try unchecking the "Display as annotation" checkbox on the Display Date/Time module. As this is the last module in the pipline adding the date/time pixels to the image will not harm successive processing ... just be sure to add any new modules BEFORE the display date/time module otherwise the date/time text will also be processed!
