math module, merge with read http Aswin from Netherlands [5 posts] |
I get my images from the read http module. Whenever I want to merge the result with the original image, using the math module, RoboRealm doesn't use the image from read http as the source but the start image. How do I set this right?
You have two choices to fix this. 1. Download the latest version of RR (just uploaded) and that will set the image captured to the source image. 2. Use the Marker module to set the image just after the HTTP_Read module to something that you would remember and then use that name in the Math module instead of Source.
