iRobot Create Module Problem
I am working with the API to control my Create using the module. Here is a snippet from the .robo file:
<IRobot_Create>
    <start_oi_mode>3</start_oi_mode>
    <Advance_Button>AdvButton</Advance_Button>
</IRobot_Create>
and my API code:
    rr.getParameter("IRobot_Create",0,"start_oi_mode", buffer, sizeof buffer);
    cout << buffer << endl;
//    rr.setParameter("IRobot_Create",0,"start_oi_mode", "2");
    for (int i = 0; i < 100; i++)
        rr.getVariable("AdvButton", buffer, sizeof buffer);
        ::Sleep(100);
This runs fine with the state of the Advance Button reported. But if the line setting the start_oi_mode module parameter runs the association of "AdvButton" name with Advance Button is lost. The state of the button is not returned.
An associated question is whether you can change the operating mode (safe, full) through a variable. I don't see a variable which is why this code use the module parameter change.
Another point is that changing the mode in the module dialog doesn't always change the mode on the Create.
RR Version 2.11.3
from United States  [60 posts] 16 year
I updated to RR 2.14.1. This problem still exists. Here is some more information.
From the .robo file:
    <advance_led_map>AdvanceLed</advance_led_map>
When the operating mode parameter is change the variable AdvButton exists but its assignment to the Advance Button is lost. The assignment of AdvanceLed using the 'map' is not lost.
Rud,
the Advance_Button variable is a read only ... i.e. the create does not do anything with the current value, just overwrites it.
Perhaps you want to use the
advance_led_value
instead?
We have also added a OI mode variable called "oi_map" that can be set to a variable that contains either Off,Passive,Safe or Full to automatically change the mode.
<Set_Variable>
  <variable_1>test</variable_1>
  <value_1>safe</value_1>
</Set_Variable>
<IRobot_Create>
  <oi_map>test</oi_map>
</IRobot_Create>
