Windows Fix in RR_API.cpp
I compiled the DevCPP program using VC++ 2005 changing the path to the excutable to be correct for my system (XP Pro SP3) which is "C:\Program Files\RoboRealm".
The program opens RoboRealm but RR generates an error dialog that "Image Filename ... is missing!". The '...' is the executable path with "C:\Program" missing. The call to CreateProcess needs the command line parameter to have quotes around the excutable file name. Otherwise RR doesn't properly receive the arg[0] parameter.
Around line 1155 the statement should be
    _snprintf(buffer, 256, "\"%s\" -api_port %d", filename, port);
Not sure what this would do on a Linux system.
Rud,
That's correct! Gotta watch out for those spaces in filenames. You can also try the abbreviated DOS version  of
c:\\Progra~1\\RoboRealm
but using the extra quotes is much cleaner.
The API examples have been updated.
