This Thread
 Reply   New Post   Forum Index
Serial Write Buffer Clearing
Pablon  [7 posts]
8 months
Buy the Phidget Adv. Servo 8 from Trossen Robotics
I test serial communication RR with PLC. The PLC consumes data from RR.
Some times, in outbound serial buffer, RR leaves data, in amount that cannot be served by PLC.
Is there possibility to clear outbound serial buffer with use of VB script?
Maybe, is there any tip or trick to do this without script?
Of course I can do this with PLC program  but because of program construction it would be batter to use RR for this.
Regards
pablon
Steven Gentner from United States  [2177 posts] 8 months
Pablon,
Just to clarify, the serial module is buffering data to be send to the PLC (most likely with a baud rate less than 115200) and what you need to do is prematurely cancel all data to be sent to the PLC using programmatic control?
So if we include a clear/cancel buffer in the serial module and allow a variable to trigger that function that would perform the functionality that you need?
Can you confirm this?
Note that it is also possible that some information will be buffered in hardware on the PC which will not be able to be cleared.
Pablon  [7 posts] 8 months
STeven,
Exactly I want to clear/cancel buffer in serial module. As far as it is possible to do with use of programming interface. So I need prematurely cancel data to be send to PLC.
Regards,
Pablon
Anonymous 8 months
Stop run robo file and start run  -seems to clear serial buffer.
I didn't find any VB Script solution for this issue.
Pablon
Pablon,
A new trigger variable was added to the serial module. If you specify a variable and then at some point set its content to "clear" it will cause the serial module to clear all outgoing data.
Please download the latest RR version and hopefully this will help in your project.
Many thanks!!
I appreciate it very much!
Regards!
Pablon
