Getting Started Mark [1 posts] |
Hi, I'm wondering if you can help me get a handle on the 'roborealm' software. I just want to know how to make it work - how to trigger a relay when a red object comes into view. Can you give me a hand?
Mark,
If you run RoboRealm and then insert the Red Ball Tracking under the +examples tree that will get you most of the way there. You will want to remove the last module (Parallax) since it is preconfigured for a Parallax USB Servo controller which you probably do not have. To get it to trigger a relay what board/MCU do you have the relay attached to? Or were you hoping to trigger the relay directly from the PC? What relay are you using?
Or if this example does not identify your red object can you include an example image of the red object?
