variable lubee from United States [12 posts] |
4 years
Hi I have another question: I use set_variables to set variable "command" of value "Pose 1" (which is from lynxmotion_seq interface) , then I am using a button_interface to set the config of one button as variable "command" and value "Pose 1". So is it supposed to do the "Pose 1" when I press that button right? Why it does not work on mine? Please throw me some advices. Thanks
4 years
4 years
4 years
actually in my .robo file, I'm using my_shape as my variable name and Triangle as my value instead of command as variable name and Pose 1 as value. It should not be a problem.
4 years
Yes it would be "Pose 1" without the quote. Also you my_shape variable should NOT have quotes around it. You also need to specify that variable in the Sequencer as the variable to grab commands from. Attached is your corrected robofile for the Triangle command.
4 years
Thanks STeven, but I am wondering if I can set maybe two or more buttons corrsponding to the value from lynxmotion_seq like the attachment I did?
How could speicfy thoes variables in the sequencer?
4 years
I tried your fiile, but it seems doesnt work for me. :(
4 years
lubeecool,
Please download the latest RR version 2.12.1 and try the attached robofile. Go into the Lynxmotion Seq and press the Server button and then the Log button in that interface. This will show you the commands coming from RoboRealm (assuming this work) and gives you an idea of what commands the variable can take.
In terms of the button interface, each button would use the same variable but set it to different values. That same variable must then appear in the Lynxmotion_Seq module in RoboRealm in order for it to transmit the command to the Lynxmotion server application.
Please note that you MUST download the latest copy for this file to work.
