Need help touching up my code!
Jonnyboy323 from United States  [13 posts]
Ok well as stated in previous posts, I have modded a usb missile launcher into a airsoft turret. The objective of the code is to find the target isolated, move to near the center of the screen, then oscillate fire on and off to prevent over heating and excessive bb use.
This code DOES NOT WORK! I have the right idea but cant get it working,
move = 0
size = GetVariable("COG_BOX_SIZE")
  if size > 10 then
    cogx = GetVariable("cog_x")
    cogy = GetVariable("cog_y")
      if cogx < 130 then
       move = move OR 4
      else
      if cogx > 222 then
         move = move OR 8
      end if
      end if
      if cogy < 101 then
        move = move OR 2
      else
      if cogy > 181 then
        move =  move OR 1
      end if
      end if
  end if
    if cogx <197 and cogx > 150  and cogy < 168 and cogy > 121 then
     step = 0
     period = 500
     period2 = 1000
    step = GetVariable("step")
      if step = 0 then
          SetVariable "move", 16
          SetVariable "step", 1
          SetTimedVariable "step", 2, period
      else
      if step = 2 then
       SetVariable "move", 0
       SetVariable "step", 3
       SetTimedVariable "step", 0, period2
      end if
    end if
  end if
SetVariable "move", move
I would love any input and have also included the roborealm file.
Thank You!
Jon
Jon,
Close .. but your use of the variable "move" and the SetVariable "move" were conflicting each other ... in essence one was overwriting the other. The last statement you have in the VBScript is SetVariable "move", move which will overwrite any previous SetVariable "move" function calls.
We rearranged your script a little and it does appear to oscillate the firing correctly once the red object is in the center of the image.
Jonnyboy323 from United States  [13 posts] 17 year
Thank you so much. I knew it was the last line but im still trying to learn VBScript. Thanks for all your help!
Jon
