Passing an Array to VB6
David Popovich from Canada  [1 posts]
I see all the good stuff for VBscript, but I have issues when I try to get an array to VB6.
What syntax or Get command should I be using?
Do I have to simply getvariable and then parse through all the commas?
Any help appreciated,
Davis
Davis,
I assume you are using the API?
Then yes, using the GetVariable and then a split on those commas would get you the array into a form factor that VB6 can use.
