Problem with RoboRealm Installation on MSRS Frank from United States [1 posts] |
I'm totally new to this package, and have followed the instructions for installing to Microsoft Robotics Developer Studio 2008 R2. I can't get the example to start, depite the fact that RoboRealm API server is up and responsive.
Below is the output. Does anyone have any suggestions? This is for a school project, and if I can't get RoboRealm working I'm going to have to switch gears quickly. Thanks in advance for any assistance on this!
-Frank
C:\Documents and Settings\Administrator\Microsoft Robotics Dev Studio 2008 R2>bi
n\dsshost /p:50000 /t:50001 /m:"Config\Interface.manifest.xml"
* Service started [10/31/2009 03:34:06][http://hp:50000/directory]
* Service started [10/31/2009 03:34:06][http://hp:50000/constructor]
* Service started [10/31/2009 03:34:06][http://hp:50000/console/output]
* Starting manifest load: file:///C:/Documents and Settings/Administrator/Micr
osoft Robotics Dev Studio 2008 R2/Config/Interface.manifest.xml [10/31/2009 03:3
4:06][http://hp:50000/manifestloaderclient]
Rebuilding contract directory cache. This will take a few moments ...
Contract directory cache refresh complete
** Error creating service. Service type:http://www.roborealm.com/2008/12/interf
ace.html [10/31/2009 03:34:14][http://hp:50000/constructor]
*** Service creation failure most common reasons:
- Service contract identifier in manifest or Create request does not match C
ontract.Identifier
- Service references a different version of runtime assemblies
Additional information can be found in the system debugger log.
[10/31/2009 03:34:14][http://hp:50000/manifestloader/c4710762-2fc6-4bf1-8867-69
f84b816dc8]
* Manifest load complete [10/31/2009 03:34:14][http://hp:50000/manifestloaderc
lient]
Frank,
Go ahead and download the RR MSRDS files again and copy the dll files into your bin MSRS folder as you had done before. This should update the dates on those files to today. We found that they were a little out of date and needed to just be recompiled and then things work out ok. Alternatively you can use C# Express, load in the Integration project and recompile from there. That should fix those errors you are seeing.
http://www.roborealm.com/downloads/MSRS_2008_Express.zip
