python 3.1
joerg from Germany  [4 posts]
i have no problems using python 2.6 as a control program for RR, but some trouble switching to python 3.1:
changing the API lines:
        raise RuntimeError, "socket connection broken"
        print data
to:
        raise RuntimeError("socket connection broken")
        print (data)
allows in python 3.1:
from RR_API import *
RR=RR_API()
RR.Connect("localhost")
but:
RR.GetVariable("FPS")
leads to an error:
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "C:\Programme\Python\lib\site-packages\RR_API.py", line 114, in GetVariab
le
    self.sock.send("<request><get_variable>"+str(name)+"</get_variable></request
TypeError: must be bytes or buffer, not str
any python expert, who can help me?
regards
Joerg
Sorry Joerg.  I have encountered the same problems and stuck with 2.6 for just this reason.
If you want to see a project (to which a joerg contributed BTW) making use of the python API look at:
http://profmason.com/?p=1084
