Motor Encoder
Menec from Greece  [5 posts]
Hi everybody,
I have a question for you.
I want to use a motor with an encoder on it.
How the pulse of the encoder can be used in RR??????
I have a ssc-32, can i do anything with this?
You will probably need another piece of hardware to interface the motor to a PC. Perhaps check out the Sabertooth line of motor controller products.
If you just want the encoder signals you could try hooking them up to the analog/digitial in of the SSC but you'd have to know more about if the encoder signals would be compatible with that sampling ... perhaps posting the Lynxmotion board with the motor/encoder types might be a good thing to try.
