Lego NXT USB Not working dll from United States [2 posts] |
I can connect to the NXT via BT just fine, but I don't have the option to connect via USB for some reason. I read that USB should be the first option in the drop down for the NXT connection, but if BT isn't on then I don't see any option to pick at all! With BT on I see that COM port but nothing else. Help!
Should I be able to see the NXT USB connection in there somewhere? BTW - both BT and USB work fine through NXT-G.
dll,
You are correct! It seems that the usb connection option was accidentally being removed from that module (Lego Mindstorms too). We've corrected that issue and uploaded a new version. See 2.4.7 for the fix.
Thanks for your note.
