Feature Request - Path Planning Variable Pranav Trehun from United States [32 posts] |
3 months
 Buy the Vex Programming Kit from Trossen Robotics |
I am using path planning for my robot. And i wanted to request a feature that will be of tremondous help to those using this module.
When ever there are obstables in the path and there is no path to destination, the plan orientation variable becomes zero. So, my robot tries to orient itself to Zero Degrees and go in that direction. As a result, it starts wandering.
If there was a variable that would indicate wether a path exists, i could use it to give a stop command if there is no path. a simple "0" for path exists and "1" for path does not exist, will be helpful.
Pranav
3 months
Steven Gentner from United States [2169 posts] |
3 months
Pranav,
See the latest version which includes a PATH_POSSIBLE variable that is created in the Path_Planning module.
Thanks for the request!
3 months
STeven,
Thank you, you're the best. Robo realm has the best support. I really appreciate it.
Keep up the good work,
Regards,
Pranav Trehun
