Feature Request - GUI slider?
bigkahuna from United States  [14 posts]
Any plans to add a "slider" type GUI element (for adjusting variable values, etc.)?
Do you mean in the Set_Variable module?
bigkahuna from United States  [14 posts] 17 year
I was thinking it would be similar to the "Button Interface", but would allow you to set a variable value within a range of values.  So for example, you would have 3 sliders labeled R, G, and B, each would have a range of 0 to 255 and thus you'd have an easy interface for setting a color.
Paul D from Canada  [45 posts] 17 year
You could make up/down buttons that make the values change and display the current value in RR.
Alternately, use VB to create a slider control. The simplest way to get the values into RR is to have the VB application update values in a text file.  That way the settings are saved for the next time the RR application is run.
See the Read Variables module.
