MEAN_COLOR and AREA Anonymous [2 posts] |
I am trying to track two specific colors, red and green. I am using the RGB filter to filter all blue and leave just those two colors. I am also using a blob filter to filter out all of the small blobs. My problem comes with the color statistics portion. I have two distinct blobs and need to discern the color and area of each of these blobs. every time i try and receive the variables from MEAN_COLOR_R(0) and MEAN_COLOR_R(1), I get garbage. one should be 0 and the other should be 255. I know MEAN_COLOR is an array as the number will fluctuate depending on the number of blobs that the camera picks up. any help will be appreciated.
Kyle,
What do you mean by "receive the variables"? What are you trying to read them with? The API?
Perhaps you can can include a robofile and image such that we can see what you are trying to do?
Don't worry about it, I found the problem. The issue was I needed to import the color data from color statistics and when I looked at the vars it showed MEAN_COLOR_R(0), so when i created a VBS file I thought I could GetVariable("MEAN_COLOR_R(0)") but it doesn't work like that, i needed to GetArrayVariable("MEAN_COLOR_R"). that worked fine, but thanks anyway :)
