Dream Cheeky USB Missle Launcher Help!!! Jonnyboy323 from United States [13 posts] |
Ok So im working on the tutorial for the usb missle launcher and ran into a problem. If i use the set variable command or try the joystick movement I can't get it to move in two directions at the same time. Like if i send 5 (1- Up 4- Left) It doesn't move at all. Is there an update in the software preventing this?
Jon
Jon,
Unfortunately this is not a software issue. When the missile launcher receives a command that specifies two simultaneous moves it simply does not move. We've verified this on the newer model. Best thing to do is to set it to either up or left but not both.
