vb.net 2008 rr api calls jaydeep from India [9 posts] |
how to use the vb.net 2008 rr api...i saw the text.vb source file but it has the sample calls for roborealms...i wnted to kno which one is the actual program where the api is written so that i can include it in my own program...all i see are other exe files but no vb source files for rr...
The VB example uses a .dll COM object ... so you can either use that COM object directly in your application or convert the c++ dll (see the COM folder for the source to that) to a VB.net counterpart. But you will have to work with low level socket calls to make this happen.
Are you not able to use the provided dll?
