cant interface with the parallel port jaydeep from India [9 posts] |
iam having trouble interfacing with the parallel port plzz help me...if i have assigned variable ugo to pin 2 and set bit 1 to transfer then if i make ugo =20 then 0 should be transferred but iam not able to change any pins either manually or by program..plzz help...
Jaydeep,
Have you checked if any of the pins are changing? Also, sometimes the OS refuses to allow an application to change the pins so be sure you are running RR as an Administrator.
You will need to give us the robofile to tell us more about what you are trying. We are not currently aware of any issues with the Parallel port.
its cool now...i didnt havd inpout32.dll ..now i have installed it and its working gud...
