cog box size variable never resets to null?
This is more a vb script question, how can I get a bunch of variables to reset after the cog module is no longer displaying on screen, basically after cog_box_size should be no existant, but it seems to stay its last value before it stopped tracking?
SetVariable "L", L
i figured it out using Movement percentage... my variables still dont work right and I'm hoping its just my understanding of the the setvariable command or something?
SetVariable "R", R
SetVariable "M", M
l= GetVariable("L")
r= GetVariable("R")
m = GetVariable("M")
move = GetVariable("MOVEMENT_PERCENT")
' get the size (width or height) of the current bounding box
size = GetVariable("COG_BOX_SIZE")
' if it is equal to "" then no object was detected
if size <> "" then
' get the horizontal center of gravity
cogX = GetVariable("COG_X")
if cogX < 20 then
l = 1
elseif cogX > 300 then
r = 1
elseif 150 < cogX < 170 then
m = 1
end if
if move = 0 then
SetVariable "L", 0
SetVariable "R", 0
SetVariable "M", 0
end if
end if
sorry to post so many times
as of now when movement is seen on screen all the variables become 1 at the same time and then turn to 0 all together when movement =0
I think the variables are getting cleared but you are not keeping yours in sync. You should not need the movement module with the following code
l= GetVariable("L")
r= GetVariable("R")
if size <> "" then
  if cogX < 20 then
    l = 1
    r = 1
    m = 1
  end if
  SetVariable "L", l
  SetVariable "R", r
  SetVariable "M", m
else
  SetVariable "L", 0
  SetVariable "R", 0
  SetVariable "M", 0
end if
Basically if size = "" then you need to also null out your variables. Remember that without using the SetVariable routine your variables will not change ... when you use l,r,m in the VBScript module they are only local to that module and are not "saved" to other parts of RoboRealm.
Jeff Sampson from United States  [1 posts] 17 year
For anyone else trying to get this to work, I had to change the following from:
if size <> "" then
to:
' if it is equal to 0 then no object was detected
if size <> 0 then
At least that is what I had to do to get it to work.
