overflow
chunhaw from Malaysia  [1 posts]
I am calculating an angle from result obtained from earlier calculation. The result return an error with OVERFLOW.
What does it mean?
What is the cause to this?
Is the number of decimals too many?
If so, what should i do?
How should i solve this problem?
Please advice, thanks.
It most likely means that you've divided something by zero ... but without the actual calculation we will not know for sure.
If you include the robofile (i.e. your RR configuration by pressing the save button and something.robo ) along with an image (also press the save button but with image.jpg) we can replicate the issue and propose a more concrete solution ...
