Keyboad send Me [1 posts] |
I´m sending caps lock. But how can i send it only once? At the moment it is going on and off,
I assume you are using either the send keyboard of receive keyboard modules. Setup a variable (run_once = true). Under Statements choose -> if statement. Now use a logical statment that has to be true before you send out the keyboard signal {CAPSLOCK}. When you send the signal, also turn the run_once do a SetVARIABLE on run once to FALSE. Thus your caps only gets sent once. Subsequenty all text you send will be in CAPS. :=)
hope this helps!
profmason
