C# getimage
Ivan from Russia  [2 posts]
I use the API In my c# program
I do:
RR_API rr = new RR_API();
Dimension d = rr.getDimension();
byte[] image = new byte[640 * 480];
d = rr.getImage(image, 640 * 480);
but in array "image" I get only zeroes (image = {0,0,0, ... ,0})
and the variable "d" is always "null"
What's the problem on your opinion?
Hi Ivan,
   Did you try the first part of the code from the API
            if (!rr.connect("localhost"))
              Console.WriteLine("Could not connect to localhost!");
              return;
Are you connecting to the server ? Is the API Server turned on in RR?
Ivan from Russia  [2 posts] 16 year
Yes, I have connection and API server started.
Ivan,
Does the line
return anything? You test case should look like
  return;
Dimension d = rr.getImage(image, 640 * 480);
as mentioned in the previous post. Seems like you are not connected correctly to the RoboRealm application. (Be sure that the app is running too!)
