Switch to Kiosk problem Paul D from Canada [45 posts] |
Small issue...
You cannot use Ctrl+K to switch to Kiosk mode if there is a module in the pipeline that starts with K. The cursor will move up to the K module before switching modes. The processing pipeline stops at the K module.
Maybe when in Kiosk mode the entire pipeline should be processed.
You can still switch to kiosk mode properly using the Options button.
Paul,
You are correct! If the application focus is in the pipeline the CTRL-K is used to select a particular module (this done by WinOS rather than by us). But if you click in the image or tree nav area and then try CTRL-K it works.
Perhaps we will disable the pipeline from accepting key commands sometime in the future.
Thanks for the note!
