Sending data to serial port Paul D from Canada [45 posts] |
I have a USB realy switch on com3 that I am trying to control in RoboRealm.
The console area works great but I cannot get Send Sequence to work with a variable. The commands are:
ON: \xFF\x01\x01 or \255\01\01
OFF: \xFF\x01\x00 or \255\01\00
When I use the variable V_BELT in the send sequence the relay doesn't respond. The data logged in the console window appears the same; lines 459 and 460 are manually and have the desired effect:
Module Started ...
Connected!
00459: \255\1\0
00460: \255\1\1
00461: \255\01\01
00462: \255\01\00
00463: \255\1\1
00464: \255\1\0
This the serial module code:
<Serial>
<enable_send_sequence>TRUE</enable_send_sequence>
<flow_control_cts>FALSE</flow_control_cts>
<read_rate_index>-1</read_rate_index>
<send_frequency_index>-1</send_frequency_index>
<send_only_on_change>TRUE</send_only_on_change>
<baud>6</baud>
<data_bits>7</data_bits>
<port>COM3 - USB Serial Port</port>
<send>[V_RELAY]</send>
<flow_control_dsr>FALSE</flow_control_dsr>
<flow_control_out_x>FALSE</flow_control_out_x>
<flow_control_in_x>FALSE</flow_control_in_x>
</Serial>
I can resort to using MSCOMM in a vbscript module but I would prefer to stick with the serial module.
Any ideas.
The variable V_RELAY is the ASCII string \255\01\01.
It serial module seems to be sending the string as ASCII as the console displays the leading zeroes.
Figured it out.
In the send sequence I put
\255\01\[V_BELT]
V_BELT is either 01 to turn the relay on (closed) or 00 to turn it off (open).
I guess the send sequence is not intended to parse strings.
I found the realy board on e-bay. They come in in 1, 2 and 8 channels from:
http://www.sigma-shop.com/shop/
