Auto_Threshold Samuel from Brazil [3 posts] |
I'm not able to change the parameters of Auto_Threshold by API in VB.NET, someone could help me?
Thank you,
Samuel
Which parameter are you trying to change using what API call?
Perhaps you can include the XML or API call that you are using that you are having issues with.
I'm using: rr.execute("<Auto_Threshold><Cluster/></Auto_Threshold>")
I need to use a Auto_Threshold with Cluster(Otsu). But, I don't know to use this parameter.
Thansk for help.
Samuel,
The easiest way to find out the correct XML string is to configure the module in the GUI, save the configuration as a .robo file and then load in that configuration using a text editor. You will see the XML that you need to send. For example the following
<Auto_Threshold>
<distance>10</distance>
<single_range>10</single_range>
<method>5</method>
<symmetry_percent>10</symmetry_percent>
<percent>50</percent>
</Auto_Threshold>
is what gets saved in a auto_threshold. There is normally more in that file than you need (depending on the config) so in your case all you need is
rr.execute("<Auto_Threshold><method>5</method></Auto_Threshold>");
and that should do the trick.
Thank's for your help Steven,
