Problem with Line corner module
lizbeth from Mexico  [1 posts]
Hi all, I hope you can help me, I want to call Line corner module from C++ and I will use execute command but I dont know the name of parameters for this module. Can you tell me what are the names I must use? or where can I found a technical specifications for this module?
Hi lizbeth
Simply save an example of the line corner module and view the .robo in notepad and you can see all the parameters you can send
<Line_Corner>
  <color_index>3</color_index>
  <minimum_line_length>5</minimum_line_length>
  <size_index>3</size_index>
  <intersect_distance>10</intersect_distance>
  <isolation_distance>5</isolation_distance>
  <create_corner_array>FALSE</create_corner_array>
  <shape_index>3</shape_index>
  <overlay_image>Current</overlay_image>
  <intersect_angle>10.0000000000</intersect_angle>
</Line_Corner>
