creating array variable
Ashok E from India  [5 posts]
        Hi... I've been searching RR and its website for the past two days looking for a way to create integer arrays... Though http://www.roborealm.com/forum/index.php?thread_id=1046#7i> gives some mode of array this stores the value as string only and cannot be used in path planning module...
      Is there any way to create a integer array of values like those created in BLOBS, HARRIS_CORNERS etc....
     I've attached the program... The program indents to path plan a path given by a series of mouse clicks...!!!
Thanks..
Ashok,
Thanks for pointing this out. We will update the documentation.
You should be able to use
ReDim points(4)
points(0) = 100
points(1) = 100
points(2) = 150
points(3) = 200
SetArrayVariable "waypoints", points
as a quick example of how to use SetArrayVariable.
