Laptop on Robot
c depalma from United States  [4 posts]
Asus makes a $400 pc called EEE 4G that uses a flash card hard disk.
It has 512 mb of ram but only 800 mhz cpu.
Has anybody tried Robo realm on a similarly configured machine?
I was hoping to use it for stereo localization using 2 web cams.
Yes, we have the $300 version. The memory is fine (RR can run full speed on a lot less) but the CPU might become the issue depending on what you want to do. For basic color tracking it is probably ok, but for using 2 webcams probably NOT. I'd recommend spending the amount on a cheap laptop with a dual core CPU that can keep up with more demanding vision tasks. Since your base is a wheelchair you don't seem to have a space/weight issue.
