Roborealm can't connect with boe-bot (serial port)
Good morning, I am following the "Why track colors?" tutorial to do a school project with my boe-bot. In the Roborealm I have added The RGBFilter, the Center of Gravity, the mean filter,the VBScript Program, the serial communications and parallax_boebot.
Now, I am lost because I do not know how does roborealm communicate with boe-bot. Could anybody tell me?
I have inserted in the boe-bot this code with basic Stamp :
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM1}
x VAR Word
y VAR Word
main:
SERIN 0,84,[WAIT ("!"),DEC4 x,DEC4 y]
PULSOUT  14, x
PULSOUT  15, y
PAUSE 5
GOTO main
After that, I have added the VBScript Program in the Roborealm program with the next code:
  ' initialize our start motor values to neutral
  left_base = 750
  right_base = 750
  ' get current image size
  width = GetVariable("IMAGE_WIDTH")
  center = width / 2
  ' get the size (width or height) of the current
  ' bounding box
  size = GetVariable("COG_BOX_SIZE")
  ' if it is equal to "" then no object was detected
  if size <> "" then
    ' get the horizontal center of gravity found by the COG
    ' module
    cogX = GetVariable("COG_X")
    ' if it is less than 75 the blob is on the left side
    ' of the screen so move that way
    if cogX < center-5 then
      left_base = 750-(center-cogX)/2
      right_base = 750
    ' otherwise move to the right if above 85 pixels (and no
    ' movement if 75 < cogX < 85 )
    elseif cogX > center+5 then
      left_base = 750
      right_base = 750-(cogX-center)/2
    end if
    ' if the ball is too close then we have to move backwards
    if (size>90) then
left_motor = left_base-((40-size)*2)
      right_motor = right_base+((40-size)*2)
' otherwise move forward
    else
      left_motor = left_base-((size-40)*2)
      right_motor = right_base+((size-40)*2)
    end if
    ' set the final motor values to be picked up by
        SetVariable "LEFT_MOTOR", CInt(left_motor)
    SetVariable "RIGHT_MOTOR", CInt(right_motor)
end if
serial send sequence for Roborealm:
! [Left_motor] <lf> [Right_motor] <lf>
Next, I have inserted serial communications and finally I have added parallax_boebot. After doing these things the boebot doesn't move, it might be some error of configuration.
can anybody help me, please?
Thank you very much
Steve Joblin from United States  [18 posts] 18 year
are you sure that the settings in the Serial module are correct... it is using the correct port, is the baud and other settings the same as what the BOEBot is looing for?  I would also make the pause statement in the BOEbot program a bit longer (try 20 ms).  Also check the size settings for the camera under Options --> Video tab --> Video format.
Edward from Spain  [10 posts] 18 year
Hello, this is my serial configuration.The port com is correct in the serial communications, it say me "connected". I don't know that number put in the baud, now I have the number (115200). Data Bits (8).  Parity (None).  Stop Bits (1). Console (Ascii).
Initialization Sequence, it's empty. In send sequence, I have "[LEFT_MOTOR] and [RIGHT_MOTOR]. In send Rate I have put "AFAP" and receive sequence it's empty.
Video format; 320x240 , color YUY2,  speed of pictures 5000.
by the end, I have also added parallax_boebot, is it correct?
with the next configuration:
Motors: LEFT(COG_Y) RIGHT(COG_X)
Input/output Pins (selected)
14 COG_X (bit 8) OUT
15 COG_Y (bit 8) OUT
Thank you very much
try reducing the video format (I don't remember the numbers, but I think it is the second smallest possible setting).
Edward,
can you include your robofile so that we can take a look at all your configuration. Just save a file using somename.robo after clicking on the Save button from the main RR interface (it is used for both images and robofiles). In your next post include that filename in the last Browse button when making a post.
Hello, the first, I am very grateful for your help.
You have my project here. Could you look if there is some mistake?
Thank you very much.
Hello. I'm sorry. The last "DOWNLOAD .robo" is wrong.
You have the good project here.  Could you look if there is some mistake?
Thank you
Edward,
Here's the robofile that we used to test this. Note that we simplified the VBScript file a little to make debugging easier. The program download to the BoeBot is
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
main:
PULSOUT  14, x
PULSOUT  15, y
PAUSE 5
GOTO main
Note that this assumes BlueTooth (the 0 in SERIN) otherwise you will need to change it to 16 (COM1 connected).
Also note that motors are on 14 and 15 as apposed to 12, 13.
See if this robofile works for you.
Note that the robot should turn to face a red object.
Hello Steven, Now the boe bot is moving but I have a problem, the boe bot doesn't turn correctly. It only run forward and When the boe doesn't detect the color It is turning left slowly.
What kind of problem is there?
I have changed the object tracking color to blue because it is better than red color.
Thank you very much
Edward,
I'd recommend trying to reduce the complexity of the VBScript part and determine what part is doing what. Keep in mind that this script was taken from a motor system that required apposing values on both motors to move forward ... this is not the case with the boebot where two equal values will move it forward. At this point you will have to experiment with the system to determine what you want to do.
We noticed that the current VBScript has been reverted back to the old one as apposed to our simplified version. Thus this is a good time to start experimenting by removing parts of the file that you don't think you need and once you understand what is happening start to add back in the parts to perform certain movements.
