Button Interface Bug
DUKEII from Belgium  [5 posts]
I've found small error in the button interface .
Variable Value only saved on START and STOP buttons , Pause and new buttons
are not saved .
kind regards
Hi DukeII,
You're probably running an older version of RoboRealm. That was indeed a bug but was fixed a while back. Can you confirm what version you are running?
The supplied robofile seems to work just fine for us. All test buttons are visible and active.
DUKEII from Belgium  [5 posts] 17 year
Hello STeven ,
When I open the ROBO sample attached in this topic with Notepad , first line gives
<head><version>1.8.11.7</version></head>
Tests with other PC give same result .
Kind regards
DukeII,
Thanks for the feedback. It looks like there was still an issue in the value saving. We think we've fixed the issue and have uploaded a fix. Please download 1.8.12.2 to get that fix.
Thanks and let us know if you notice any other issues in that module.
STeven ,
I've done some tests on this module and it almost perfect .
The only thing I have is when the name of the original Start button is changed
sometimes it saved and somethimes not .(incl.variable and toggle settings)
With lot of experiments I didn't find what the reason is .
All the other buttons where properly saved .
Thanks for the quick response
