Yang from United States [2 posts] |
Is there any way to extract the time (in ms) as a variable for export/programming? I'm using the Display_DateTime module, but it doesn't seem to be storing the time as a variable I can see.
MS timing is going to be a little tricky. If you want to use just seconds you can set a variable (using the Set_Variable module) to the current time (see NOW in the dropdown list in the Set_Variable module).
For ms timing, you will have to use the VBScript module to run
SetVariable "time_in_ms", Timer
which gives you number of seconds with a fractional part (ie sub second timing).
Hopefully that should give you want you want.
That's exactly what I needed. Thanks!
