3D position
hi!
I have 2 cameras.I want to use to find 3D position (x,y,z) of a point(red  point).
how can I setup a system to do this?
First try detecting the point in one camera successfully by perhaps using the RGB filter. Then move on to the COG module to find the middle of the red dot. Once this is in a variable use the marker module to switch to the next image. Repeat for this new image and then use the VBScript to calculate the difference between the two X coordinates.
Try to get started, once you get stuck post the image and robofile to this forum so that we can all help you move along.
