Roborealm Vbscript Problem
I dont know if Im posting this in the right place but i have a small problem with roborealm vbscript module, how do i make a delay between commands that i have written in the vbscript ?
See the following url on the sleep command http://mikesalsbury.com/mambo/content/view/133/
Also have a look at this previous post on the usage of SetTimedVariable.
http://www.roborealm.com/forum/index.php?thread_id=2080#2
Hello everyone...
Below are my variables in VBScript.
shapeLabel = GetStrVariable("SHAPE_LABEL")
if shapeLabel = square then
  SetVariable "left_motor", 0
  SetVariable "right_motor", 255
  SetVariable "coordinate_i", 0
  SetVarivale "coordinate_j", 0
else
  if shapeLabel = circle then
    SetVariable "left_motor", 255
    SetVariable "right_motor", 0
    SetVariable "coordinate_j" 100
  else
  end if
end if
I want the coordinate value appear in screen. but when i apply the display variable.. no value of coordinate appear. pliz help me.
First off you are missing quotes around the comparisons to square and circle. Try
if shapeLabel = "square" then
else
  if shapeLabel = "circle" then
  else
  end if
end if
and watch the case too ... ie is it "square", "Square" or "SQUARE"
what if i want to use Cscript?
char*shapelabel = getVariable("shape_label");
int left_motor;
int right_motor;
int coordinate_i;
int cooridnate_j;
if (shapelabel = 'square')
left_motor = 60;
right_motor = 128;
coordinate_i = 0;
coordinate_j = 100;
else
  if (shapelabel = 'circle')
    left_motor = 128;
    right_motor = 60;
        coordinate_i = 0;
         coordinate_j = 200;
  else
    left_motor = 128;
    right_motor = 128;
        coordinate_i = 100;
        coordinate_j = 200;
setVariable("left_motor", left_motor);
setVariable("right_motor", right_motor);
setVariable("coordinate_i", coordinate_i);
setVariable("coordinate_j", coordinate_j);
why is it wrong?
Try "==" instead of a single equal
should be
shapelabel == 'square'
thank you. How shall i write 'case' in VBScript?? so that the landmarks can be detect in sequence?
Do you mean select case ? http://www.w3schools.com/vbscript/tryit.asp?filename=vbdemo_selectcase
