vb.net API sample is not work Justin Ratliff from United States [3 posts] |
When I try to run the vb.net API sample I get the following error: "Cannot create ActiveX component." in reference to this line of code: "rr = CreateObject("RoboRealm.API.1")"
I have no earthly idea why that is erroring out at run time. Any ideas what I might be doing wrong?
Does any one has a sample of a different vb.net API interface they might be able to send me at: Weyoun7@aol.com
-Justin
You may have missed the comment in the code that reads
' DON'T FORGET TO regsvr32 \path\API\RR_COM_API.dll before running!!
ie run
before running the example.
Perhaps give that a try first.
Well, for goodness sakes, I was making it more difficult than it needed to be.
When I read: regsvr32 \path\API\RR_COM_API.dll for the "path" I thought I needed to enter C:\RoboRealm\API..... When I removed the C: it accepted the registry update and the program sample for VB.Net work perfectly.
Thank You STeven
