Strange...Error???
Mohit from India  [2 posts]
while using RR API of by any language like VC++ or java, i am getting following error-
Could not connect to any VFW video capture devices. Is your video camera/device plugged in?
Can any one please help me out of this.
Regards,
Mohit Srivastava
Can you try connecting to your camera just using the RoboRealm interface. Does it work then? If so then you are probably not specifying the camera string correctly. You will need to use the exact string that you see in the Options->Video dropdown as the camera string in the API. If it is not a match the system will attempt to connect to another camera that might explain why you are seeing this message.
First check things with the RoboRealm GUI, then if ok move to the API.
