Changing a tutorial file crashes roborealm
I've just been trying to change the filter in the program given in this post from a yellow car to a red car and roborealm crashes. It happends every time I try to do it.
Can you see why this happens?
Best regards
Ian R
Ian,
It appears to have something to do with the specific image that you are using. Can you post the non-bayer version of the image (i.e. the original image) in this post and we'll see if that makes a difference. Without the image the switch of the RGBFilter from Yellow to red seems to work fine. It is most likely that when switched to yellow something in the image is causing it to crash.
