VBScript Byte Variable
Frank Zhao from Canada  [6 posts]
The code won't run if I put
Dim name As Byte
to declare a variable, is the syntax wrong?
I really need to use non-floating and unsigned 8 bit numbers for my projects
Thanks for the help
Hi Frank
Dim name As Byte is correct syntax for Visual Basic not vbscript just use Dim name.
VbScript variables are always of the same kind or type see See http://www.4guysfromrolla.com/webtech/032801-1.shtml
Frank Zhao from Canada  [6 posts] 16 year
Thanks! Not something I'm used to but I can get by with it.
