iandi,
You should be able to use the
if isArray(your_array) then
  .. code ..
end if
to check to see if any harris points have been detected. You should also use ubound to check to see how many elements there are before proceeding with your code.
  if ubound(your_array) >=4 then
    .. code ..
  end if
end if
This should prevent the VBScript from erroring and allow you to better handle the error cases.
Does this solve your problem?
many thanks for your quick reply!! Its very much appreciated.
I will try this and will post the result.
Thanks again!!!
iandi
