Jim,
I'd check that d:\\Savoir\\ELE\\roborealm\\RoboRealm.exe is the correct path on your laptop. Then I'd run it in debug mode on your laptop and verify where the error is happening ... note that you have all the code and thus you can check it in VC line by line.
If you don't want to install VC on your laptop then do the printf or file write and log where the error is happening. The statement it errors on may be more helpful than just knowing it errors.
It's my mistake, I had copied the files .cpp from my PC to my laptop but forgot to change the directory of roborealm.exe...
Now it works!
Thank you !
Jim
