export to a stand alone program Anonymous |
is there a way that a compleated RR program can be exported into its own program.
E.g. the DC launcher joystick control be exported to its own program so RR does not have to be running at the same time. all that this would requre is the camera with a smiple boarder and how to control it (joystick)
Unfortunately no, a RoboRealm program (robofile) is simply an XML styled text file that specifies a configuration to load. You need RoboRealm to run, load and understand that configuration file. Currently there is no way to create a standalone program that does not require RoboRealm to run ... but you can distribute the robofile such that others can run the same "program".
